[GRASS-dev] CVS branch problem
Wed May 16 23:50:21 EDT 2007
Markus Neteler wrote:
> Hi,
> I wanted to backport the v.dissolve column support to the
> 6.2 release branch, but
> bartok:v.dissolve[3553.44] cvs ci -m"backported col support"
> cvs commit: Examining .
> cvs server: sticky tag `releasebranch_6_2' for file `description.html'
> is not a branch cvs server: sticky tag `releasebranch_6_2' for file
> `v.dissolve' is not a branch cvs [server aborted]: correct above
> errors first!
> >>From  http://owen.sj.ca.us/rkowen/howto/cvs.html I got that
> the tag isn't on the branch (or so) and I tried:
> bartok:v.dissolve[3554.45] cvs tag -b -r releasebranch_6_2
> releasebranch_6_2 cvs server: Tagging .
> W Makefile : releasebranch_6_2 already exists on version 1.1 : NOT
> MOVING tag to branch 1.1.0.2 W description.html : releasebranch_6_2
> already exists on version 1.1 : NOT MOVING tag to branch 1.1.0.2 W
> v.dissolve : releasebranch_6_2 already exists on version 1.1 : NOT
> but the problem persists. Suggestions welcome. AFAIR the v.dissolve
> was added later to the branch (and hence the mess).
Yes. Apparently I added v.dissolve and v.centroids to releasebranch_6_2
as a tag and not a branch. I'm not sure how to fix that.
http://www.psc.edu/~semke/cvs_branches.html
I used something like:
 cvs up -j HEAD v.dissolve
 cvs tag -r HEAD releasebranch_6_2 v.dissolve
Hamish
