[GRASS-dev] Re: [GRASSGUI] Re: [grass-addons] r659 - trunk/grassaddons/gui/gui_modules
Thu May 17 18:17:39 EDT 2007
Michael Barton wrote:
> This is helpful. But I will wait to make any changes until this is worked
> out--since it looks like we will also need to redefine the original command
> string (i.e., to make it a proper list) prior to calling cmd.Command.
I've fixed cmd.Command itself and all of the straightforward uses.
AFAICT, GUI.parseCommand() is probably still broken:
menuform.py:1075:        cmdlst = cmd.split(' ')
