[GRASS-dev] Re: [GRASSGUI] Re: [grass-addons] r659 -
trunk/grassaddons/gui/gui_modules
Glynn Clements
glynn at gclements.plus.com
Thu May 17 21:30:47 EDT 2007
Michael Barton wrote:
> >> This is helpful. But I will wait to make any changes until this is worked
> >> out--since it looks like we will also need to redefine the original command
> >> string (i.e., to make it a proper list) prior to calling cmd.Command.
> > I've fixed cmd.Command itself and all of the straightforward uses.
> So we'll need to send it a list consisting of [command+flags, option=val,
> option=val,...]. Right?
Example:
dbDescribe = cmd.Command (cmd = ["db.describe", "-c",
"table=%s" % self.parent.tablename,
"driver=%s" % self.parent.driver,
"database=%s" % self.parent.database])
> > AFAICT, GUI.parseCommand() is probably still broken:
> > menuform.py:1075: cmdlst = cmd.split(' ')
> This actually might be fine. It looks like it is only checking to see if
> there is a space in the command string and returning an error message is
> there is. It making sure that the only thing being passed on to menuform is
> a simple GRASS command without arguments.
Ah; okay.
