[GRASS-dev] g.mapsets use of sleep()
Markus Neteler
neteler at itc.it
Fri May 18 09:54:31 EDT 2007
Moritz Lennert wrote on 05/18/2007 01:58 PM:
> On 16/05/07 22:58, Markus Neteler wrote:
>> [ MinGW compile errors for sleep() ]
>> Glynn Clements wrote:
>>> ... use G_sleep() instead:
>>> >From lib/gis/sleep.c:
>>> unsigned int G_sleep (unsigned int seconds)
>>> #ifdef __MINGW32__
>>> /* TODO: no sleep for now */
>>> return 0; #else /* __MINGW32__ */
>>> return sleep(seconds);
>>> #endif /* __MINGW32__ */
>>> On MinGW, it doesn't actually sleep, but at least you don't get a link
>>> error.
>> I have added there code for MinGW to use Sleep() and updated
>> all remaining sleep() to G_sleep().
> The implementation you used does not work:
> #ifdef __MINGW32__
> return Sleep((seconds)*1000);
> #else
> The problem is that Sleep is void and thus does not give a value you
> can return (http://msdn2.microsoft.com/en-us/library/ms686298.aspx).
> We need something like this:
> #ifdef __MINGW32__
> return 0;
> #else
I have fixed it like this for now.
Markus
> Just not sure: is 0 the correct value to return ? IIUC this is the
> value returned by the unistd.h version of sleep.
> Moritz
ITC -> dall'1 marzo 2007 Fondazione Bruno Kessler
ITC -> since 1 March 2007 Fondazione Bruno Kessler
