[GRASS-dev] g.mapsets use of sleep()
Fri May 18 12:24:37 EDT 2007
Moritz Lennert wrote:
> Just not sure: is 0 the correct value to return ? IIUC this is the value
> returned by the unistd.h version of sleep.
RETURN VALUE
       Zero if the requested time has elapsed, or the number of  seconds  left
       to sleep.
It will return non-zero if sleep() is interrupted by a signal before
the requested number of seconds has elapsed.
AFAICT, nothing in GRASS actually uses the return value, so you could
just re-define G_sleep() as void.
