[GRASS-dev] g.mapsets use of sleep()
Fri May 18 14:01:56 EDT 2007
Glynn Clements wrote:
> AFAICT, nothing in GRASS actually uses the return value, so you could
> just re-define G_sleep() as void.
I've done this.
