[GRASS-dev] gis.m: font selection in module panels
Moritz Lennert
mlennert at club.worldonline.be
Sun May 20 09:27:22 EDT 2007
Michael,
Thanks for the font selection in the module panels, but I have the
following problem. I can select the font the first time, but when I try to
open the font dialog a second time in the same panel, I get:
can't read "env(GRASS_FONT)": no such variable
while executing
"if {[info exists env(GRASS_FONT)] && $env(GRASS_FONT) != ""} {
set fontindex [lsearch $fontlist $env(GRASS_FONT)]
if {$fontindex > -1} {
(procedure "Gm:DefaultFont" line 26)
invoked from within
"Gm:DefaultFont dbarscale"
(procedure "GmBarscale::set_font" line 5)
invoked from within
"GmBarscale::set_font 1"
("uplevel" body line 1)
invoked from within
"uplevel \#0 $cmd"
(procedure "Button::_release" line 18)
invoked from within
"Button::_release .mainframe.frame.pw1.f1.frame.sw.sf.frame.fr.color.d"
(command bound to event)
Moritz
