[GRASS-dev] GEM Wizard question
Yann yann.chemin at gmail.com
Mon May 21 06:01:37 EDT 2007
Thanks Ben,
Is there anybody that knows abit a tcltk that could add info about where it
should go coding wise?
Yann
On Monday 21 May 2007 14:31, Benjamin Ducke wrote:
> I guess it wouldn't be too much trouble. GEM already has all that's
> needed for this: zipped extension packages can be downloaded (using
> wget), unzipped (to system's temp dir) and installed automatically.
> There is just one catch: since all files are installed into system-wide
> locations, the wizard will probably need superuser rights. So a tcl/tk
> based install wizard needs to provide a way to get the superuser
> password and run system commands with elevated rights.
> It would be a cool thing to have, I agree.
> Ben
> Yann wrote:
> > Hello,
> > Would it be possible to create a kind of Wizard to assist
> > download/install of extensions with GEM?
> > 1-locate GEM enabled extensions (http://wiki...)
> > 2-Download in ~/tmp
> > 3-run gem on it
> > Yann
> > grass-dev mailing list
> > grass-dev at grass.itc.it
> > http://grass.itc.it/mailman/listinfo/grass-dev
Yann Chemin
Sainte-Anne d'Auray, France
