[GRASS-dev] can wxPython GUI handle order of options for v.type and alike?
Maciej Sieczka tutey at o2.pl
Tue May 22 17:44:22 EDT 2007
Hi
I was wondering if the wxPython GUI is going to deal with problems the
tcl/tk GUI can't - when there is a set of pre-defined parameters to
choose from and the user should be able to decide about the order of them.
An example is v.type [1], for which in the tcl/tk GUI you can specify
the order of types only one way, eg. 'type=point,centroid', but
'type=centroid,point' is impossible to achieve.
[1]http://intevation.de/rt/webrt?serial_num=2969
Maciek
