[GRASS-dev] RE: [GRASS-user] problems with r.cost
Wed May 23 19:02:21 EDT 2007
Jerry Nelson wrote:
> The large file support option doesn't help with all grass routines
> unfortunately.
> The following has to be in the Make file for the specific module
> ifneq ($(USE_LARGEFILES),)
>         EXTRA_CFLAGS = -D_FILE_OFFSET_BITS=64
> Endif
> It is not in the r.cost Make file, which means I think (remember I'm not a C
> programmer) that compiling with large file support won't help.
For r.cost, adding the above to lib/segment/Makefile would probably be
of more use.
I've been through that code recently, and I'm reasonably sure that
it's safe for LFS.
