[GRASS-dev] r.colors -w ?
Maciej Sieczka
tutey at o2.pl
Mon May 28 11:51:40 EDT 2007
Hamish wrote:
> Can someone explain when you would want to use the new "r.colors -w"?
from the manual:
"If the user specifies the -w flag, the current color table file for
the input map will not be overwritten. This means that the color table
is created only if the map does not already have a color table. If this
option is not specified, the color table will be created if one does
not exist, or modified if it does."
Maciek
