[GRASS-dev] r.colors -w ?
Glynn Clements
glynn at gclements.plus.com
Mon May 28 19:50:52 EDT 2007
Hamish wrote:
> Can someone explain when you would want to use the new "r.colors -w"?
It isn't a new option; it has been there since at least 5.3, probably
a lot longer. It allows you to add a colour table only if one doesn't
already exist.
The -r option is new. It allows you to remove an overriding colour
table in colr2/<mapset>/<name> and revert to the original colour table
in <mapset>/colr/<name>.
