[GRASS-dev] Star in the grass programing
Juan Diego Giraldo Osorio Juan.Giraldo at upct.es
Tue May 29 11:10:17 EDT 2007
Hi everybody
Thanks for help me. But, the problems are new. I had found the r.example
executable file in the directory:
/home/jdgiraldo/grass-6.2.1/dist.x86_64-unknown-linux-gnu/bin
I access in this directory (cd /home/...) and try to execute the r.example:
./r.example
the mistakes are the next:
./r.example: error while loading shared libraries: libgrass_gis.so:
cannot open shared object file: No such file or directory
I have this file (libgrass_gis.so) in
/usr/local/grass-6.2.1/lib/libgrass_gis.so
Thanks again.
UPCT
España
> On 29/05/07 15:30, Juan Diego Giraldo Osorio wrote:
> > Hi Glynn
> > I had ran the "make" file, and I have a directory
> > (OBJ.x86_64-unknown-linux-gnu) in r.example (together with the main.c,
> > makefile, ... files). In OBJ.x86_64-unknown-linux-gnu directory I found
> > and object file (main.o). Excuse me, but I don't know what to do with
> > this file. Can I execute it from grass??? Compile it with gcc??? Run it
> > directly???
> You should also find an executable r.example in
> dist.i486-pc-linux-gnu/bin
> This is the module you can run.
> Moritz
