[GRASS-dev] Star in the grass programing
Moritz Lennert mlennert at club.worldonline.be
Tue May 29 09:52:58 EDT 2007
On 29/05/07 15:30, Juan Diego Giraldo Osorio wrote:
> Hi Glynn
> I had ran the "make" file, and I have a directory
> (OBJ.x86_64-unknown-linux-gnu) in r.example (together with the main.c,
> makefile, ... files). In OBJ.x86_64-unknown-linux-gnu directory I found
> and object file (main.o). Excuse me, but I don't know what to do with
> this file. Can I execute it from grass??? Compile it with gcc??? Run it
> directly???
You should also find an executable r.example in
dist.i486-pc-linux-gnu/bin
This is the module you can run.
Moritz
