[GRASS-dev] GRASS 6.2.2RC1 released
Markus Neteler
neteler at itc.it
Tue May 29 19:26:07 EDT 2007
Dear all,
a first release candidate of the new 6.2.2 has been published today:
http://grass.itc.it/grass62/source/
grass-6.2.2RC1.tar.gz (12M)
It will be on the mirrors within 1-2 days.
Numerous issues have been resolved:
* System and Libraries:
o DBMI/SQL parser: added missing TIME support
o DBF Driver: add missing SQL TIME support
o sqlite driver: 'date' support
o QGIS-GRASS DB bug: fixed https://svn.qgis.org/trac/ticket/448
o geodetic datum:enable geodetic datum for Krovak, Slovakia
datum (hermannskogel) fixed
* Graphical User Interface:
o gis.m: Backport various GIS.m GUI enhancements. Clickable
GUI buttons; More robust error handling; Main window
cosmetics; Fix lwidth bug; Typos
o GUI menu: remove non-functional font setting entries
o GUI startup: backport Michael's new EPSG code search tool
* Modules/Scripts:
o d.labels: backport rotation fixes
o d.vect: display also nodes in topo mode
o d.vect.thematic: remove Bashisms
o v.clean tool=snap: doubled vertices in the output
o g.mremove: work also in gis.m
o lib/gis: backport false easting/northing test
o ps.map: Fix landscape mode. Fix map scaling when map
projection is not measured in meters
o r.contour: fix segfault
o r.distance: null distance for area in area
o r.flow: 3d length fix; 64bit segfault fix
o r.in.bin: honour -s flag for 2-byte and 4-byte data
o r.pro Allow data from stdin; die if coordinate request
outsite current region settings, was reporting bogus data
o r.proj bilinear: Fix interpolation expression
o r.reclass.area: don't leave clump file behind, label support
added
o v.build.polylines: fails to build a polyline out of a
closed boundary, vertices are doubled at each node
o r.tileset: Fix break due to platform specific units
parsing; Requires Bash
o scripts/: various fixes backported, remove all bashisms
from Bourne scripts
o Slovakia Hermannskogel datum fixed again
o v.build.polylines: two bugs: #4247 #4249
o v.dissolve: dissolve common boundaries by attribute
o v.in.ascii: skip blank lines,
o v.in.gpsbabel: attribute import fixed for tracks and routes
o v.in.region: add additional vertex if necessary to ensure
line segments don't exceed 180 degrees longitude
o v.lidar.*: various fixes backported
o v.report: backported fixes for RT bug #4459 and
[grass-code I][#301]
o v.segment: Make side_offset functional
o v.to.db: fix compactness formula parentheses to match
actual formula
o v.type: Wrap it so it works from the GUI menus
o v.what: fix for multiple input coords
A draft announcement is found here:
http://grass.itc.it/announces/announce_grass622.html
The related Wiki page which also list the contributors is here:
http://grass.gdf-hannover.de/wiki/GRASS_6.2_Feature_Plan#6.2.2
Please test this release candidate as much as possible.
Thanks to all contributors and testers.
Markus
View this message in context: http://www.nabble.com/GRASS-6.2.2RC1-released-tf3837300.html#a10864724
Sent from the Grass - Dev mailing list archive at Nabble.com.
