Markus Neteler wrote: > you have to run GRASS commands *inside* GRASS, means, that > you have to launch GRASS first. Then all paths will be > defined. To start the version of GRASS which has just been compiled, without having to install it, run "bin.i486-pc-linux-gnu/grass62". -- Glynn Clements <glynn at gclements.plus.com>
