[GRASS-dev] Problems with wish
Scott Mitchell
smitch at mac.com
Wed May 30 15:19:42 EDT 2007
I believe if you set the GRASS_WISH environment variable before
starting GRASS that could get around this for you.
E.g.:
export GRASS_WISH=wish8.4 (then start GRASS)
However, it also suggests that a link between wish8.4 and wish is
missing on your system. On my linux and macosx systems, /usr/bin/
wish is a symbolic link to /usr/bin/wish8.4
You could make the same thing with
sudo ln -s /usr/bin/wish8.4 /usr/bin/wish
(that's assuming your wish8.4 is in /usr/bin).
On 30-May-07, at 07:44 , Juan Diego Giraldo Osorio wrote:
> Agustin
> I started grass with
> [jdgiraldo at labitf08 ~]$ grass62
> and the prompt shows
> GRASS 6.2.1 (SENEGAL):~ >
> I'm working in a Mapset called SENEGAL.
>> From here I access to r.example's directory:
> GRASS 6.2.1 (SENEGAL):~ > cd grass-6.2.1/dist.x86_64-unknown-linux-
> gnu/bin
> GRASS 6.2.1 (SENEGAL):~/grass-6.2.1/dist.x86_64-unknown-linux-gnu/
> bin >
> and here I try to execute r.example:
> bin >
> ./r.example
> sh: wish: command not found
> "ERROR"
> Again, I think that grass doesn't call the suitable command (wish8.4
> instead wish) but I don't know how (or where) redir the code.
> Thanks
> Juan
>> Juan,
>> You need to start grass before, something like ./grass.sh or simply
>> grass6, and once grass is started , you will see the following
>> GRASS 6.3.cvs (Projecte):/your path/ >
>> There is where you need to put r.example
>> Best
>> n May 30, 2007, at 1:06 PM, Juan Diego Giraldo Osorio wrote:
>>> Hi coworkers
>>> Now I have compiledand installed the grass-6.2.1 package with the
>>> following instruction:
>>> ./configure --with-postgres-includes=/usr/local/pgsql/include
>>> --with-postgres-libs=/usr/local/pgsql/lib --enable-64bit
>>> --with-libs=/usr/lib64
>>> the procedure don't show problems. However, when I try to execute
>>> ./r.example in /dist.x86_64-unknown-linux-gnu/bin the prompt shows:
>>> I have tcl8.4 and tk8.4. when I execute "wish8.4" tk runs without
>>> problems. I think that the problem is the grass isn't executing the
>>> correct command, but I don'k know how to redir to wish8.4 instead
>>> wish.
>>> Thanks
>>> Juan
>>>> On Wed, May 30, 2007 at 05:39:19AM +0100, Glynn Clements wrote:
>>>>> Markus Neteler wrote:
>>>>>> you have to run GRASS commands *inside* GRASS, means, that
>>>>>> you have to launch GRASS first. Then all paths will be
>>>>>> defined.
>>>>> To start the version of GRASS which has just been compiled,
>>>>> without
>>>>> having to install it, run "bin.i486-pc-linux-gnu/grass62".
>>>> Hi Juan,
>>>> once you have it all working for you - please let us know where
>>>> and how to better document it!
>>>> Markus
>>>> ITC -> dall'1 marzo 2007 Fondazione Bruno Kessler
>>>> ITC -> since 1 March 2007 Fondazione Bruno Kessler
>>> grass-dev mailing list
>>> grass-dev at grass.itc.it
>>> http://grass.itc.it/mailman/listinfo/grass-dev
