[GRASS-dev] wms in wxgrass?
Thu May 31 04:52:48 EDT 2007
> > Agustin Diez Castillo wrote:
> >> Today, I have been able to use r.in.wms for the first time with
> >some > success,
> > good news!
> >> Others are giving me some errors beyond both my capabilities
> >> and their capabilities. The mapserver in the example works in QGis
> >> and others,
> >> I can't get even the capabilities
> >> r.in.wms mapserver=http://ovc.catastro.meh.es/Cartografia/WMS/
> >> ServidorWMS.aspx -l
> > I have just made the error handling better in CVS, could you update
> > and try once again?
> I will update and keep checking.
> > That shows the real error was:
> > "Este servicio sirve para ser utilizado por programas de
> > visualización de cartografía. No es una página web."
> > you should see that now, both for the layers list and the broken
> > download. Sorry, I can't help you with the server error itself.
> It says that this service have been developed for cartographic
> applications. This is not a web page. So the error is not help as far
> as grass is the best cartogpraphic application I'm aware of and I'm
> not looking for a web page.
I really don't know enough about WMS servers to answer.
The help page mentions adding "?" to the URL, but that doesn't help.
> >> WARNING: xml2 NOT avaliable
> I knew that, and I think it is there /Library/Frameworks/
> libxml.framework/Versions/2.6.26/Resources/Scripts/xml2-config.
> > xml2 is a program, it's not needed, but helps parse the XML better
> > if it's there.
> >   http://ofb.net/~egnor/xml2/
xml2-config is something else, part of Gnome's libxml. It's needed to
compile xml2, but xml2 is something more.
$ apropos xml2-config
xml2-config (1)      - script to get information about the installed
version of GNOME-XML
Hamish
