[GRASS-dev] native winGRASS pre-alpha testers needed
Markus Neteler
neteler at itc.it
Mon May 28 12:22:49 EDT 2007
Moritz Lennert wrote on 05/25/2007 10:44 AM:
> On 24/05/07 18:36, Markus Neteler wrote:
>> On Thu, May 24, 2007 at 06:10:46PM +0200, Moritz Lennert wrote:
>>> On 24/05/07 17:35, Paolo Cavallini wrote:
>>>> -----BEGIN PGP SIGNED MESSAGE-----
>>>> Hash: SHA1
>>>> Markus Neteler ha scritto:
>>>>> - DBF access failed (r.to.vect in our case; this we really need to
>>>>> fix)
>>> Could you be a bit more specific about what failed how ?
>> They wanted to use r.to.vect to convert [r.]watershed basins to
>> vector polygons. Doing so, r.to.vect was whining about DBF. I don't
>> have the detailed error message since it wasn't my machine - sorry.
>> Maybe you/someone could try r.watershed + r.to.vect?
> r.watershed elevation=elevation.dem at PERMANENT threshold=100
> basin=basins stream=streams half.basin=half_basins visual=watershed_vis
> r.to.vect input=streams at user1 output=streams feature=line
> works perfectly for me.
> The same for
> r.to.vect input=basinsuser1 output=basins feature=area
> If you (or the people who did the tests) can provide more details, I
> could try again.
> Moritz
> grass-dev mailing list
> grass-dev at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass-dev
ITC -> dall'1 marzo 2007 Fondazione Bruno Kessler
ITC -> since 1 March 2007 Fondazione Bruno Kessler
