No subject
Wed Nov 14 13:37:45 EST 2007
your region borders are way out in space.
With following values (Wagner II) I don't see the latitudal wraps
(assuming here a resolution of 10000m):
north: 9280000
south: -9280000
east: 18560000
west: -18560000
cols: 3712
rows: 1856
e-w resol: 10000
n-s resol: 10000
There are really no good guidelines published on how you should set the
NSEW borders for locations in different projections in GRASS. Here (as I
usually do) I made the distances west-east and south-north even multiples
of the ew_ and ns_ resolution, respectively, but also even multiples of
the number of columns and cells, respectively. (And multiples of 8 as
well, but that is just my preference and may not be important).
I arrived at these values through:
proj +ellps=WGS84 +proj=wag2
0 90
0.00 9265609.63
180 0
18531288.84 0.00
and then took the even multiples slightly larger than the maximum
northing/easting values given by proj.
I have no problems with bordwalk() cropping the results.
Does this, with the changes you suggested to PROJ, solve it?
Morten Hulden
