No subject
Wed Nov 14 13:37:45 EST 2007
(using grass-6.1.cvs-i686-pc-linux-gnu-21_01_2006.tar.gz on Redhat 9.0)
GRASS 6.1.cvs (lcra):~/grassinstall > r.terraflow elev=test filled=test_out direction=test_dir swatershed=test_shed accumulation=test_acc tci=test_tci
r.terraflow December 2003
region size is 28458 x 28438
cell test header compatible with region header
elevation stored as FLOAT (4B)
STREAM temporary files in /var/tmp  (THESE INTERMEDIATE STREAMS WILL NOT BE DELETED IN CASE OF ABNORMAL TERMINATION OF THE PROGRAM. TO SAVE SPACE PLEASE DELETE THESE FILES MANUALLY!)
MFD flow direction
D8CUT=999999986991104.000000
memory size: 300.00M (314572800) bytes
Memory manager registering memory in MM_WARN_ON_MEMORY_EXCEEDED mode.
reading data from test to stream /var/tmp/STREAM_Ke0baI:    63%  File size limit exceeded (core dumped)
GRASS 6.1.cvs (lcra):~/grassinstall > ls -lh /var/tmp/
total 2.1G
-rw-------    1 endeitz  endeitz      2.0G Jan 27 13:43 STREAM_Ke0baI
GRASS 6.1.cvs (lcra):~/grassinstall > dd if=/dev/zero of=testsize bs=1024k count=3000
3000+0 records in
3000+0 records out
total 5.0G
-rw-r--r--    1 endeitz   endeitz      2.9G Jan 27 13:47 testsize
----------------------------------end output
Thanks,
Ed.
View this message in context: http://www.nabble.com/Re%3A-GRASSLIST%3A7448-Re%3A-r.terraflow-failured-t130887.html#a2627756
Sent from the Grass5 - Dev forum at Nabble.com.
------=_Part_3178_7483784.1138401841621
Content-Type: text/html; charset=us-ascii
Content-Transfer-Encoding: 7bit
