No subject
Wed Nov 14 13:37:45 EST 2007
<br>
<br>(using grass-6.1.cvs-i686-pc-linux-gnu-21_01_2006.tar.gz on Redhat 9.0)
<br>
<br>-----------------------------------------------
<br>GRASS 6.1.cvs (lcra):~/grassinstall &gt; r.terraflow elev=test filled=test_out direction=test_dir swatershed=test_shed accumulation=test_acc tci=test_tci
<br>r.terraflow December 2003
<br>region size is 28458 x 28438
<br>cell test header compatible with region header
<br>elevation stored as FLOAT (4B)
<br>STREAM temporary files in /var/tmp &nbsp;(THESE INTERMEDIATE STREAMS WILL NOT BE DELETED IN CASE OF ABNORMAL TERMINATION OF THE PROGRAM. TO SAVE SPACE PLEASE DELETE THESE FILES MANUALLY!)
<br>MFD flow direction
<br>D8CUT=999999986991104.000000
<br>memory size: 300.00M (314572800) bytes
<br>Memory manager registering memory in MM_WARN_ON_MEMORY_EXCEEDED mode.
<br>reading data from test to stream /var/tmp/STREAM_Ke0baI: &nbsp; &nbsp;63% &nbsp;File size limit exceeded (core dumped)
<br>
<br>GRASS 6.1.cvs (lcra):~/grassinstall &gt; ls -lh /var/tmp/
<br>total 2.1G
<br>-rw------- &nbsp; &nbsp;1 endeitz &nbsp;endeitz &nbsp; &nbsp; &nbsp;2.0G Jan 27 13:43 STREAM_Ke0baI
<br>
<br>GRASS 6.1.cvs (lcra):~/grassinstall &gt; dd if=/dev/zero of=testsize bs=1024k count=3000
<br>3000+0 records in
<br>3000+0 records out
<br>
<br>total 5.0G
<br>-rw------- &nbsp; &nbsp;1 endeitz &nbsp; endeitz &nbsp; &nbsp; &nbsp;2.0G Jan 27 13:43 STREAM_Ke0baI
<br>-rw-r--r-- &nbsp; &nbsp;1 endeitz &nbsp; endeitz &nbsp; &nbsp; &nbsp;2.9G Jan 27 13:47 testsize
<br>
<br>----------------------------------end output
<br>
<br>Thanks,
<br>
<br>Ed.
<br>
<br><hr align="left" width="300">
View this message in context: <a href="http://www.nabble.com/Re%3A-GRASSLIST%3A7448-Re%3A-r.terraflow-failured-t130887.html#a2627756">Re: r.terraflow failured</a><br>
Sent from the <a href="http://www.nabble.com/Grass5---Dev-f1210.html">Grass5 - Dev</a> forum at Nabble.com.
------=_Part_3178_7483784.1138401841621--
