Glynn Clements wrote: > 3. Additional utilities: > sqlite3 v.db.join This doesn't seem to make sense either. v.db.join doesn't actually use sqlite3 (it uses GRASS DB modules to do all of the work), it just refuses to run if you don't have it. -- Glynn Clements <glynn at gclements.plus.com>
