[GRASS-dev] Wingrass and TclTk
Mon Nov 26 19:15:32 EST 2007
Glynn Clements wrote:
> > 3. Additional utilities:
> > sqlite3			v.db.join
> This doesn't seem to make sense either. v.db.join doesn't actually use
> sqlite3 (it uses GRASS DB modules to do all of the work), it just
> refuses to run if you don't have it.
I've removed this check.
