[GRASS-dev] SoC projects to trunk
Benjamin Ducke
benjamin.ducke at ufg.uni-kiel.de
Fri Nov 2 07:37:54 EDT 2007
For gis.m, look into:
GRASSBASE/etc/gm/gmmenu.tcl.
Just copy a menu entry and work from there. I am sure you
will find it easy enough to understand the syntax.
One hint: be careful to get closing ] brackets right.
Benjamin
Wolf Bergenheim wrote:
> Hi list,
> I have now brought the two SoC modules (v.generalize and
> v.net.visibility) to the CVS trunk. I would appreciate it very much if
> someone could check the code once again :) just to make sure it is
> suitably stable.
> I would also love it if someone could help me add these new modules to
> the gui. v.net.visibility should probably go next to the other v.net.*
> modules, but what about generalize? Should it go under Develop map?
> I'll look into how to add these there myself, but any hints are appreciated.
> --Wolf
Benjamin Ducke, M.A.
Archäoinformatik
(Archaeoinformation Science)
Institut für Ur- und Frühgeschichte
(Inst. of Prehistoric and Historic Archaeology)
Christian-Albrechts-Universität zu Kiel
Johanna-Mestorf-Straße 2-6
D 24098 Kiel
Germany
Tel.: ++49 (0)431 880-3378 / -3379
Fax : ++49 (0)431 880-7300
www.uni-kiel.de/ufg
