[GRASS-dev] select issue with wingrass
Michael Barton
michael.barton at asu.edu
Fri Nov 9 13:19:33 EST 2007
On 11/9/07 11:04 AM, "Moritz Lennert" <mlennert at club.worldonline.be> wrote:
> On 09/11/07 16:25, Michael Barton wrote:
>> This is a help. I'm going to try to get a student in my lab to try it too.
> Please also try it with the spearfish demo location.
Did this.
>>> How are you creating the points ?
>> v.in.db. We are using a dbf file that we've created in OpenOffice (to avoid
>> Excel issues). It certainly looks perfectly good.
> It is quite probable that this will probably not work because of the
> current bug in the dbf driver. Although AFAICT this should not cause a
> windows dll error...
> Could you try creating an sqlite table with the same data and use
> v.in.db on that ?
> You have to make sure that the sqlite executable (and I think library)
> are in your path.
> You can set the PATH in the grass63.bat file:
> set PATH=%PATH%;PathToSqliteBin;PathToSqliteLib
Can do that. But the issue is simply trying create points from a DBF. This
is important for my teaching next semester too. Insisting that students try
to figure out SQLite isn't very feasible.
I thought that the dbf error was fixed. If not, it is good to know that
v.in.db doesn't work currently. We can just use v.in.ascii instead.
>>>> Also getting an error on gdal import complainging about a gcs.cvs file
>>> Haven't used gdal import for a while in wingrass, so will test that.
Got this dealt with. Interestingly, trying to import a file with an
incorrect format with v.in.ascii gives the same error as trying to import a
dbf file with v.in db, using dbf format. I don't know if this helps debug,
but maybe it is a clue.
>>>> ERROR 4: Unable to open EPSG support file gcs.csv.
>>>> Try setting the GDAL_DATA environment variable to point to the
>>>> directory containing EPSG csv files.
>>> Have you tried setting this ?
>> How would we go about setting this?
> Try setting it in the grass63.bat file:
> set GDAL_DATA=
You mean leave this blank/empty? Or do you mean to point this variable to a
valid location?
> But is this a GRASS variable or a GDAL variable ?
I have absolutely no idea.
> Moritz
Thanks for the help.
Michael
Michael Barton, Professor of Anthropology
Director of Graduate Studies
School of Human Evolution & Social Change
Center for Social Dynamics and Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
