[GRASS-dev] help file incorrect for v.in.ascii
Moritz Lennert mlennert at club.worldonline.be
Sat Nov 10 05:18:05 EST 2007
Michael Barton wrote:
>>> I just tested something and found out that the helpfile is incorrect for
>>> v.in.ascii (although  my often faulty memory was correct).
>>> The helpfile says that you can specify which columns are used for the x and
>>> y coordinates.
>> this is correct.
>>> However, this generates an error.
>> what's the error? sample input file?
> The error is something about an incorrect number of columns. The file was a
> very simple one for just 2 points
Are you sure the column separator was defined correctly ? Whenever I got
this error this was always the problem.
Moritz
