[GRASS-dev] help file incorrect for v.in.ascii
Michael Barton michael.barton at asu.edu
Sat Nov 10 11:33:24 EST 2007
On 11/10/07 3:18 AM, "Moritz Lennert" <mlennert at club.worldonline.be> wrote:
> Michael Barton wrote:
>>>> I just tested something and found out that the helpfile is incorrect for
>>>> v.in.ascii (although  my often faulty memory was correct).
>>>> The helpfile says that you can specify which columns are used for the x and
>>>> y coordinates.
>>> this is correct.
>>>> However, this generates an error.
>>> what's the error? sample input file?
>> The error is something about an incorrect number of columns. The file was a
>> very simple one for just 2 points
> Are you sure the column separator was defined correctly ? Whenever I got
> this error this was always the problem.
Absolutely. We used the same column separator and same way of specifying it
in both cases.
Michael
> Moritz
Michael Barton, Professor of Anthropology
Director of Graduate Studies
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
