[GRASS-dev] X11 trouble on OSX 10.5
William Kyngesburye woklist at kyngchaos.com
Mon Nov 12 11:50:50 EST 2007
On Nov 12, 2007, at 10:13 AM, Michael Barton wrote:
> One Mac issue I need to mention. In the current cvs version (on
> 10.4) GRASS
> help no longer is listed in my Help Library, although the GRASS
> addons help
> IS listed. It's not a huge issue as help comes up OK from within
> GRASS, but
> it was handy having it in the library listing too.
The install puts a symlink in /Library/Documentation/Help.  If you
move or rename the GRASS app after install, this will break, but as
you found g.manual still knows where the files are.
One idea that's been pushed to the back of my brain is to install the
actual help files in the Documentation folder.  But this would
complicate g.manual and GUI help references, and the bindist installer
package setup.
> Michael
>> More info, I forgot: the GUI splash displays just before this error.
>> Definitely something wrong in TclTk 8.5.  The GUI runs with 8.4
>> (32bits).
>> The reason I tried 8.5 is that 8.4 does not build 64bits on OSX
>> (configure actually removes any 64bit flags you try to add).  I
>> suppose the GUI itself doesn't need to run in 64bits, as long as the
>> modules are 64bits they will run as such.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
Earth: "Mostly harmless"
- revised entry in the HitchHiker's Guide to the Galaxy
