[GRASS-dev] select issue with wingrass
Paul Kelly
paul-grass at stjohnspoint.co.uk
Tue Nov 13 05:45:45 EST 2007
On Mon, 12 Nov 2007, Michael Barton wrote:
>> 3. v.in.ascii input
>> v.in.ascii input=C:/grassdata/MR.csv output=MR format=point fs=,
>> skip=0 x=1 y=2 z=0 cat=0 --overwrite
> What is the error here?
Are you running that from the command console? If so I think it is a
similar problem of needing to use Windows rather than Unix syntax. Try
c:\grassdata\MR.csv for the pathname (backslashes instead of forward
slashes). Would also (obviously) help to see the error message but at a
first glance that's what I can see is wrong with it.
Paul
