[GRASS-dev] where= and cats= to all vector commands
Massimiliano Cannata
massimiliano.cannata at supsi.ch
Thu Nov 15 05:12:47 EST 2007
+1
I think it would be really useful and standardize the inputs for vector
commands.
I agrre that if one want to merge cat and where he can add in the where
clause.
At this point is cats necessary?
Maxi
Moritz Lennert wrote:
> On 15/11/07 10:09, Wolf Bergenheim wrote:
>> Hi developers,
>> What do you people think of the idea to add where= and cats= parameters
>> to all vector commands? Also add any missing layer= parameter (like with
>> v.voronoi).
> +1
>> What should be the case where both cats and where is supplied? Ideally
>> merging it so that first do the where, and then limit the result to only
>> cats in the given list? Or output a warning that where takes precedence
>> over cats?
> I would go for the second. If people really need to merge the two,
> they can use cats=X in the where clause.
> Moritz
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
Dr. Massimiliano Cannata
Environmental & Geomatic Engineer
Institute of Earth Scences - SUPSI
Trevano, C.P. 72, CH-6952 Canobbio, SWITZERLAND
Tel: +41 (0)58 / 666 62 14
Fax: +41 (0)58 / 666 62 09
E-mail: massimiliano.cannata at supsi.ch
Web:
http://www.ist.supsi.ch
http://istgis.ist.supsi.ch:8001/geomatica/
