[GRASS-dev] where= and cats= to all vector commands
Martin Landa
landa.martin at gmail.com
Thu Nov 15 05:31:21 EST 2007
maybe connected, should be vector modules (except of selected modules
like v.build, etc.) region sensitive similary to raster modules (for
GRASS7)?
Martin
2007/11/15, Massimiliano Cannata <massimiliano.cannata at supsi.ch>:
> +1
> I think it would be really useful and standardize the inputs for vector
> commands.
> I agrre that if one want to merge cat and where he can add in the where
> clause.
> At this point is cats necessary?
> Maxi
> Moritz Lennert wrote:
> > On 15/11/07 10:09, Wolf Bergenheim wrote:
> >> Hi developers,
> >> What do you people think of the idea to add where= and cats= parameters
> >> to all vector commands? Also add any missing layer= parameter (like with
> >> v.voronoi).
> > +1
> >> What should be the case where both cats and where is supplied? Ideally
> >> merging it so that first do the where, and then limit the result to only
> >> cats in the given list? Or output a warning that where takes precedence
> >> over cats?
> > I would go for the second. If people really need to merge the two,
> > they can use cats=X in the where clause.
> > Moritz
> > grass-dev mailing list
> > grass-dev at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/grass-dev
> Dr. Massimiliano Cannata
> Environmental & Geomatic Engineer
> Institute of Earth Scences - SUPSI
> Trevano, C.P. 72, CH-6952 Canobbio, SWITZERLAND
> Tel: +41 (0)58 / 666 62 14
> Fax: +41 (0)58 / 666 62 09
> E-mail: massimiliano.cannata at supsi.ch
> Web:
> http://www.ist.supsi.ch
> http://istgis.ist.supsi.ch:8001/geomatica/
Martin Landa <landa.martin at gmail.com> * http://gama.fsv.cvut.cz/~landa *
