[GRASS-dev] submitting bugs
Hamish
hamish_nospam at yahoo.com
Thu Nov 15 22:45:09 EST 2007
Dylan Beaudette wrote:
> should new bug reports[1] be submitted to the existing tracker, or wait
> until the osgeo move is done?
Me, I'd say file it, but I'm not the one doing the work ;)
> 1. saving the results from a monitor, after setting the font to a TTF, does
> not result in the TTF being respected when d.rast is used- however does work
> when d.his is used...
d.rast (without -o) erases the screen history when it runs, as it runs full
screen. d.his doesn't. run d.font after d.rast, or d.rast -o.
d.font remembers the font being used as long as the monitor is open, so it will
appear like it is still on the list even though it has been cleared from the
command list. Running d.out.file etc using the current list in another monitor
will not know about the previously set font.
Hamish
____________________________________________________________________________________
Be a better sports nut! Let your teams follow you
with Yahoo Mobile. Try it now. http://mobile.yahoo.com/sports;_ylt=At9_qDKvtAbMuh1G1SQtBI7ntAcJ
