[GRASS-dev] submitting bugs
Fri Nov 16 06:52:37 EST 2007
Hamish wrote:
> > 1. saving the results from a monitor, after setting the font to a TTF, does
> > not result in the TTF being respected when d.rast is used- however does work
> > when d.his is used...
> d.rast (without -o) erases the screen history when it runs, as it runs full
> screen.  d.his doesn't.  run d.font after d.rast, or d.rast -o.
That should probably be filed as a bug in d.rast.
