Glynn Clements wrote: > > d.rast (without -o) erases the screen history when it runs, as it runs full > > screen. d.his doesn't. run d.font after d.rast, or d.rast -o. > > That should probably be filed as a bug in d.rast. I've removed this "feature" from d.rast. It no longer clears the window. -- Glynn Clements <glynn at gclements.plus.com>
