[GRASS-dev] GRASS cvs for Mac compilation fails for OS X 10.4
William Kyngesburye
woklist at kyngchaos.com
Sat Nov 17 15:28:08 EST 2007
On Nov 17, 2007, at 12:54 PM, Agustin Diez Castillo wrote:
> I use bindist in several Macs with some success,
Some success - were there problems then?
> actually one of them is working in
> Leopard
Do you mean: generating the installer on Tiger and installing on
Leopard? That should work. The only thing to watch out for is that
on Leopard you should NOT set DISPLAY - the Terminal startup magic
takes care of this, and setting it yourself will break X displays and
the GUI.
> but I need to write the command gis.m on the terminal.
So, the GUI is not starting automatically?
>> I'm curious: are you using a bindist-created installer package? or
>> building from source on each Mac? I haven't heard any feedback from
>> anyone on the bindist feature (it's what I use it to create my
>> binaries for download).
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"This is a question about the past, is it? ... How can I tell that the
past isn't a fiction designed to account for the discrepancy between
my immediate physical sensations and my state of mind?"
- The Ruler of the Universe
