[GRASS-dev] GRASS cvs for Mac compilation fails for OS X 10.4
Agustin Diez Castillo
Agustin.Diez at uv.es
Sun Nov 18 12:52:46 EST 2007
> On Nov 17, 2007, at 12:54 PM, Agustin Diez Castillo wrote:
> > I use bindist in several Macs with some success,
No until now, but I haven't used it a lot.
> Some success - were there problems then?
> > actually one of them is working in
> > Leopard
> Do you mean: generating the installer on Tiger and installing on
> Leopard? That should work. The only thing to watch out for is that
> on Leopard you should NOT set DISPLAY - the Terminal startup magic
> takes care of this, and setting it yourself will break X displays and
> the GUI.
I will check that.
> > but I need to write the command gis.m on the terminal.
> So, the GUI is not starting automatically?
Yes, the GUI is not starting automatically.
> >> I'm curious: are you using a bindist-created installer package? or
> >> building from source on each Mac? I haven't heard any feedback from
> >> anyone on the bindist feature (it's what I use it to create my
> >> binaries for download).
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "This is a question about the past, is it? ... How can I tell that the
> past isn't a fiction designed to account for the discrepancy between
> my immediate physical sensations and my state of mind?"
> - The Ruler of the Universe
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
Dr. Agustín Diez Castillo
Departament de Prehistòria i Arqueologia
Fundació General Universitat de València
Phone: +34 963 86 42 42
Avda. Blasco Ibañez, 28 Fax: +34 963 86 42 34
València 46010
