[GRASS-dev] GRASS cvs for Mac compilation fails for OS X 10.4
William Kyngesburye woklist at kyngchaos.com
Sun Nov 18 13:22:12 EST 2007
On Nov 18, 2007, at 11:52 AM, Agustin Diez Castillo wrote:
>>> but I need to write the command gis.m on the terminal.
>> So, the GUI is not starting automatically?
> Yes, the GUI is not starting automatically.
Hm, if it doesn't start automatically, but will start manually, then
the DISPLAY setting is probably OK - it wouldn't even start manually
if this was wrong.  It may simply be defaulting to 'text' and you need
to change your GRASS_GUI setting:
g.gisenv set="GRASS_GUI=tcltk"
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
[Trillian]  What are you supposed to do WITH a maniacally depressed
robot?
[Marvin]  You think you have problems?  What are you supposed to do if
you ARE a maniacally depressed robot?  No, don't try and answer, I'm
50,000 times more intelligent than you and even I don't know the
answer...
- HitchHiker's Guide to the Galaxy
