[GRASS-dev] true type font question
Hamish
hamish_nospam at yahoo.com
Sun Nov 18 06:52:05 EST 2007
> Michael Barton wrote:
> > I'm trying to find out if this is a general issue, a Mac problem, or just
> > a problem with my stuff.
> > It used to be that whenever I displayed anything with text, it would
> > default to Romans unless I set the font to something else.
> > Now, displaying something with text displays NOTHING at all unless I
> > manually set the font globally (config menu) or in a particular module.
> > Is anyone else seeing this? Or is it just me?
Moritz Lennert wrote:
> We had the same problem in wingrass and it was due to etc/fontcap not
> being correctly written during install (wrong path names). Running
> g.mkfontcap in ant open grass session solved the problem.
this suggests a need for a fail-safe fallover to a default value (romans) on
error, instead of setting the font to "".
Hamish
____________________________________________________________________________________
Get easy, one-click access to your favorites.
Make Yahoo! your homepage.
http://www.yahoo.com/r/hs
