[GRASS-dev] true type font question
Glynn Clements
glynn at gclements.plus.com
Sun Nov 18 10:30:26 EST 2007
Hamish wrote:
> > We had the same problem in wingrass and it was due to etc/fontcap not
> > being correctly written during install (wrong path names). Running
> > g.mkfontcap in ant open grass session solved the problem.
> this suggests a need for a fail-safe fallover to a default value (romans) on
> error, instead of setting the font to "".
The problem is that the code which initialises the font doesn't work
if etc/fontcap doesn't have an entry for "romans".
