[GRASS-dev] select issue with wingrass
Glynn Clements
glynn at gclements.plus.com
Sun Nov 18 10:33:16 EST 2007
Moritz Lennert wrote:
> I have advanced a little bit trying to debug this, although I have no idea
> why this has suddenly appeared and wasn't there all the time, and I'm,
> therefore, not sure that this is really the origin of the problem.
> select.tcl uses both the GISDBASE and MAPSET env variables.
They aren't supposed to be environment variables.
I'm surprised that select.tcl has worked so far. It should be using
g.gisenv to get those values.
