[GRASS-dev] Patch for d.vect.thematic
Harri Kiiskinen harri.kiiskinen at utu.fi
Fri Nov 23 10:30:19 EST 2007
Hello,
attached is a small patch that fixes a small bug in d.vect.thematic:
Other layers than 1 could not be used as sources for attribute data. The
reason is quite obvious: in determining the column type through v.info,
the layer was set to 1 instead of $GIS_OPT_LAYER.
Best Wishes,
Harri K.
Index: d.vect.thematic
RCS file: /home/grass/grassrepository/grass6/scripts/d.vect.thematic/d.vect.thematic,v
retrieving revision 1.56
diff -u -r1.56 d.vect.thematic
--- d.vect.thematic	12 Nov 2007 17:52:13 -0000	1.56
+++ d.vect.thematic	23 Nov 2007 15:19:02 -0000
@@ -240,7 +240,7 @@
 MAX_LEG_ITEMS=18
 # check column type
-COLTYPE="`v.info -c $GIS_OPT_MAP layer=1 2> /dev/null | grep -w $GIS_OPT_COLUMN | cut -d'|' -f1 | tr -s '[:upper:]' '[:lower:]'`"
+COLTYPE="`v.info -c $GIS_OPT_MAP layer=$GIS_OPT_LAYER 2> /dev/null | grep -w $GIS_OPT_COLUMN | cut -d'|' -f1 | tr -s '[:upper:]' '[:lower:]'`"
 #COLTYPE=...
 if [ -z "$COLTYPE" ] ; then
