[GRASS-dev] Patch for d.vect.thematic
Moritz Lennert
mlennert at club.worldonline.be
Fri Nov 23 10:38:37 EST 2007
On 23/11/07 16:30, Harri Kiiskinen wrote:
> Hello,
> attached is a small patch that fixes a small bug in d.vect.thematic:
> Other layers than 1 could not be used as sources for attribute data. The
> reason is quite obvious: in determining the column type through v.info,
> the layer was set to 1 instead of $GIS_OPT_LAYER.
Comitted. Thank you very much !
Moritz
