[GRASS-dev] [grass-code I][539] "Delete" or "remove" the name of g.remove?
grass-dev at lists.osgeo.org grass-dev at lists.osgeo.org
Sat Nov 24 20:12:31 EST 2007
code I item #539, was opened at 2007-11-25 01:12
Status: Open
Priority: 3
Submitted By: Nikos Alexandris (nikosa)
Assigned to: Nobody (None)
Summary: "Delete" or "remove" the name of g.remove?
Issue type: None
Issue status: None
GRASS version: CVS HEAD
GRASS component: None
Operating system: None
Operating system version:
GRASS CVS checkout date, if applies (YYMMDD):
Initial Comment:
It's my first post here... so maybe I should post this somewhere else, since it's not really about a bug.
In GRASS 6.3.cvs the g.remove command (under Manage maps and volumes) is named "delete".
Shouldn't everything be either remove (g.remove, Remove a map and the message in the Output GIS.m "Removing ... ") or delete (g.delete, Delete a map and "Deleting ...) ?
You can respond by visiting:
http://wald.intevation.org/tracker/?func=detail&atid=204&aid=539&group_id=21
