[GRASS-dev] [grass-code I][539] "Delete" or "remove" the name of g.remove?
Maciej Sieczka tutey at o2.pl
Sun Nov 25 04:13:57 EST 2007
grass-dev at lists.osgeo.org wrote:
> In GRASS 6.3.cvs the g.remove command (under Manage maps
> and volumes) is named "delete".
> Shouldn't everything be either remove (g.remove, Remove a
> map and the message in the Output GIS.m "Removing ... ")
> or delete (g.delete, Delete a map and "Deleting ...) ?
Anybody minds renaming the "Delete" entry in gis.m into
"Remove"?
Would "Remove" be really better?
Maciek
