[GRASS-dev] Fwd: Re: [GRASS-user] scientific notation
Martin Landa
landa.martin at gmail.com
Sun Nov 25 06:53:14 EST 2007
2007/11/25, Hamish <hamish_nospam at yahoo.com>:
> Fwd from Ivan, I wonder how G_scan_easting() and G_scan_northing() fit into
I do not fully understand this notation
> this problem? (for 1.2345e6 not 123:45:54.321E; 31E needs to be considered
> East)
anyway
$ cat pok.txt
123:45:54.321E|80N
1.2376508917e2|80N
$ v.in.ascii in=pok.txt out=pok
$ v.out.ascii pok
123.76508917|80|1
123.76508917|80|2
works for me...
Martin
> --Hamish
> Note: forwarded message attached.
> ____________________________________________________________________________________
> Be a better sports nut! Let your teams follow you
> with Yahoo Mobile. Try it now. http://mobile.yahoo.com/sports;_ylt=At9_qDKvtAbMuh1G1SQtBI7ntAcJ
> ---------- Messaggio inoltrato ----------
> From: Ivan Shmakov <ivan at theory.asu.ru>
> To: Hamish <hamish_nospam at yahoo.com>
> Date: Sun, 25 Nov 2007 15:36:50 +0600
> Subject: Re: [GRASS-user] scientific notation
> >> Can GRASS actualy deal with number written with scientific notation ?
> >> Is there a specific way to deal with these numbers ?
> > v.in.ascii coulumn scanning code seems to overlook that case.
> Since my message has apparently not reached grass-dev, and since
> you're interested in this problem, I'm forwarding it to you.
> The problem seems to me somewhat trivial to solve.
> To: Martin Landa <landa.martin at gmail.com>
> Date: Sat, 24 Nov 2007 22:35:48 +0600
> Subject: Re: scientific notation
> >>>>> Martin Landa <landa.martin at gmail.com> writes:
> >> I would like to import points data in GRASS (with v.in.ascii). My
> >> data includes number written with the scientific notation (for
> >> example 1.2e+23). During the import, I am defining them as double.
> >> Unfortunately, it doesn't work...
> >> I get the following message :
> >> " ERROR: Column 9 defined as double has string values "
> > no, it seems, v.in.ascii doesn't support it...
> It seems that it's the is_double () function which behaves in a
> wrong way:
> $ nl -ba grass-6.3.cvs_src_snapshot_2007_11_03/vector/v.in.ascii/points.c
> 30 /* Determine if the string is double, e.g. 123.456, +123.456, -123.456
> 31 * return 1 if double, 0 otherwise */
> 32 static int is_double(char *str)
> 33 {
> 34 int i = -1, ndots = 0;
> 35
> 36 while (str[++i] != '\0') {
> 37 if (i == 0 && (str[i] == '+' || str[i] == '-'))
> 38 continue;
> 39
> 40 if (str[i] == '.') {
> 41 if (ndots > 0)
> 42 return 0; /* > 1 dot */
> 43
> 44 ndots++;
> 45 continue;
> 46 }
> 47
> 48 if (!isdigit(str[i]))
> 49 return 0;
> 50 }
> 51
> 52 return 1;
> 53 }
> IIUC, the number is to be converted from its string
> representation by atof () later. Since, I assume, atof ()
> supports e-notation, there's no necessity in such a strict check
> like is_double () currently performs. Therefore, I suggest
> is_double () to be reimplemented on top of strtod () instead,
> e. g.:
> static int
> is_double (char *s)
> char *tail;
> if (strtod (s, &tail),
> tail == s || *tail != '\0') {
> /* doesn't look like a number,
> or has extra characters after what looks to be a number */
> return 0;
> return 1;
> BTW, is_int () could be rewritten as well.
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
Martin Landa <landa.martin at gmail.com> * http://gama.fsv.cvut.cz/~landa *
