[GRASS-dev] z value from raster to vect
Andruit at gmx.de
Andruit at gmx.de
Mon Nov 26 10:34:24 EST 2007
i have question concerning c Programming and vektor Files.
I extracted some points out of a dem and created a vector file.
Points = Vect_new_line_struct();
Cats = Vect_new_cats_struct ();
if (0 > Vect_copy_xyz_to_pnts (Points, xarray, yarray, NULL, n_points))
G_fatal_error ("Vect_copy error\n");
Vect_write_line (Map, type, Points, Cats);
as a result I get several vector points, but they are not connected to a database and so they don´t ave any Information about the z value.
I would like to write the z value into a table, so that I can interpolate between the vector points.
I´m a newbie in grass Programming. Does anyone know how to do it???
Thank you
GMX FreeMail: 1 GB Postfach, 5 E-Mail-Adressen, 10 Free SMS.
Alle Infos und kostenlose Anmeldung: http://www.gmx.net/de/go/freemail
