[GRASS-dev] Re: WinGrass testing results 6.3.0rc2
Benjamin Ducke
benjamin.ducke at ufg.uni-kiel.de
Tue Nov 27 06:22:43 EST 2007
Moritz Lennert wrote:
> On 27/11/07 11:07, Paul Kelly wrote:
>> On Tue, 27 Nov 2007, Benjamin Ducke wrote:
>>>>> NVIZ won?t launch (but did in a recent binary)
>>> This can be somewhat tricky. For me, it fails to launch from within
>>> the MSYS shell
> I cannot confirm this: If I launch grass using /c/grass/bin/grass63
> (i.e. the shell launch script, not the .bat), nviz works perfectly for
> me, both from the gui and from the comand line.
> (You have to change the definition of GISBASE from c:/ syntax to /c/
> syntax for it to work...I've corrected this in the wingrass6.3RC2
> package now)
Cool. I'll try that as soon as I can.
>>> as well as a sh.exe started via Window's cmd.exe.
> Could you be more precise as to what exactly you are doing ? Do you
> launch grass via grass63.bat and then launch sh.exe within a running
> grass session ?
Yes, exactly. I have sh.exe and friends in my system PATH.
>> That might be because the Msys shell doesn't recognise a .bat file
>> (in this case nviz.bat) as an executable and/or can't run it. What
>> happens if you add the GRASS scripts directory ($GISBASE/scripts
>> IIRC) to your path? Then it should pick up the nviz shell script that
>> will (should be???) installed in there.
OK, I'll try that, too.
> If you run grass in msys you have to run the grass63 file which then
> calls Init.sh which sets the path to the scripts directory.
Good point.
Cheers,
Benjamin
> Moritz
Benjamin Ducke, M.A.
Archäoinformatik
(Archaeoinformation Science)
Institut für Ur- und Frühgeschichte
(Inst. of Prehistoric and Historic Archaeology)
Christian-Albrechts-Universität zu Kiel
Johanna-Mestorf-Straße 2-6
D 24098 Kiel
Germany
Tel.: ++49 (0)431 880-3378 / -3379
Fax : ++49 (0)431 880-7300
www.uni-kiel.de/ufg
