[GRASS-dev] [grass-code R][541] r.series method=max_raster should produce CELL
Wed Nov 28 13:46:33 EST 2007
grass-dev at lists.osgeo.org wrote:
> code R item #541, was opened at 2007-11-28 16:37
> Status: Open
> Priority: 3
> Submitted By: Harri Kiiskinen (harrikoo)
> Assigned to: Nobody (None)
> Summary: r.series method=max_raster should produce CELL
> Issue status: None
> GRASS component: raster
> Operating system: all
> Operating system version:
> Initial Comment:
> It would be quite logical if the r.series with method=max_raster
> would produce a CELL instead of DCELL - the data is integers showing
> the position of the map in the input= parameter, after all.
The issue applies to the count, min_raster, max_raster and diversity
methods.
I'll commit a fix shortly.
