[GRASS-dev] [grass-code I][544] Map Display crashes when zooming
(too much) in!
grass-dev at lists.osgeo.org
Wed Nov 28 19:01:47 EST 2007
code I item #544, was opened at 2007-11-29 00:01
Status: Open
Priority: 3
Submitted By: Nikos Alexandris (nikosa)
Assigned to: Nobody (None)
Summary: Map Display crashes when zooming (too much) in!
Issue type: other bug
Issue status: None
GRASS version: CVS HEAD
GRASS component: display
Operating system: Linux
Operating system version: Ubuntu 7.10
GRASS CVS checkout date, if applies (YYMMDD):
Initial Comment:
.The Display Crashes when zooming in too much in a specific point (in a raster map) displayed in Map Display.
.First error message is: Error setting region: child process exited abnormally
.Second error message (after pressing ok): Error: can't read "parts(projection)"...
can't read "parts(projection)": no such variable
while executing
"regexp -nocase {^.* (\(.*\))} $parts(projection) trash end"
(procedure "MapCanvas::runprograms" line 46)
invoked from within
"MapCanvas::runprograms $mon [expr {$mymodified != 0}]"
(procedure "MapCanvas::drawmap" line 38)
invoked from within
"MapCanvas::drawmap $mon"
(procedure "MapCanvas::display_server" line 9)
invoked from within
("after" script)
.Don't know if g.region -p is necessary to report... (just for any case):
GRASS 6.3.cvs (Peloponnese_HGRS87):~/> g.region -p
projection: 99 (Transverse Mercator)
zone: 0
datum: towgs84=-199.87,74.79,246.62
ellipsoid: grs80
north: 4255230
south: 3994272
west: 226090
east: 468372
nsres: 249.95977011
ewres: 250.03302374
rows: 1044
cols: 969
cells: 1011636
[Raster MASK present]
You can respond by visiting:
http://wald.intevation.org/tracker/?func=detail&atid=204&aid=544&group_id=21
